I am working on a project focused on glare caused by reflected light from curtain wall glass surfaces.
I would like to input the material properties of the glass (reflectance) using a modifier. However, the translucent modifier allows only the input of diffuse reflectance, which limits accuracy.
On the other hand, using the mirror modifier seems exaggerated, as it assumes the glass is a perfect mirror, which is an oversimplification. Additionally, the DGP (Daylight Glare Probability) results are unrealistically high and unreliable in this scenario.
Could you recommend a suitable modifier to use for this context?
