Hi @MatteoMerli,
Thank you for your response. About your question I am using the airflow network, i have seen in this other conversation to change the airflownetworkcontrol to input instead of surfaceaveragecalculation, but i am not sure if this can be set directly in the additional string input for open studio.
I have ended up doing it manually as @LittleBuddha sugessted
However not ideal, i belive it does the trick. If you can think on any other way i would love to heat about it. The idea is to remove the pressure coefficients from the simulation or being able to set how much influence i want the wind to have in my model.
Cheers
