Dear LBT developers,
If you find some time to look into my very simple model
ComfortPlotTest.gh (34.5 KB), you see that I have trouble finding a way to plot adaptive comfort data and obtain comfort metrics based on occupied intervals only.
Specifically:
- LB Hourly plot: when I send occupancy data as a second data set to the component, it just plots it on the primary data set (which is not ideal), and when I connect a statement such as “b>0” to cut out vacant intervals, it crashes.
- LB Comfort Statistics: No input for a secondary data set such as occupancy.
Would these components work if I filter the datasets in advance? I am a bit worried to mess up timestamps, as it is not very explicit in LB data format.
In any case, I think it would be great if LB hourly plot (and perhaps LB Comfort Statistics) allows for such a processing using secondary datasets.
All the best,
Farhang
