Replacing the PVgen component in HB_legacy
I am updating my old algorithm with the latest HB version components. However, I couldn’t find the corresponding PVgen component in the latest version of HB. May I ask if there is a component for defining PV panels in the new HB? Thanks
Hi @Ivanitap, there are PV components in the new HB.
The sample file can be found here.
If you aren’t seeing them in the toolbar under 4::HVAC try running the versioner component.
Thanks @TrevorFedyna. I downgraded from 1.7.1 / 1.7.26 to 1.7.0 and found the component. But it has this error code
“1. Solution exception:
Failed to import honeybee_energy:
cannot import generator from honeybee_energy”
For the latestion version of HB (1.7.1 and above), I cannot find the component even updated the versioner.
Hi @Ivanitap try running the pollination grasshopper one-click installer, I just used it and checked the two PV components were present in honeybee energy 4::
Thanks @TrevorFedyna . It works =)
