I have two questions about modelling HVAC in Ironbug, that I hope @MingboPeng or someone else can answer.
- Does anyone know a way to output the temperature and air flows of nodes with Ironbug?
Alternatively other ways to see if my HVAC system supplies the temperatures and air flows as intended.
- Is it possible to control the Terminal VAV dampers from specific temperature and CO2 curves?
In this case I want to control the air flow in each room by a curve of the room conditions. Examples of curves can be seen below:
CaseSimplifiedLBForum.gh (174.5 KB)
Best regards
William Eskildsen
