I used Rhino6 with LB on a mac with version 11.4 and LB with radiance.
I want to start my simulation, but i have this error on my pac. I don’t installed windows or using that. So i don’t understand the problem.
Have anyone a solution?
That’s just a generic error for a failed recipe @Elli.akr .
To see the real error, you will have to use the report_out_ option on the “HB Recipe Settings” component or you can check the logs that are probably in:
