I would like to know if there is a known issue with Rhino 7 and Therm.
In Rhino 6, I am able to get a definition to identify nurbs surfaces as “surfaces” when I run the script in Rhino 7, the surface called an “open Surface” and therm spits back errors. I am using new versions of Rhino and Ladybug, but an OLD tutorial script for the analysis.
The file is called
Analyze_THERM_Results_for_Condensation_Risk
I will upload the file for easier reference once my permissions have been activated.
I did try to search the Ladybug forums, but I did not see this issue solved.
Below, it looks like others have had this issue, and just continue to work in rhino 6.
Is this the correct course of action?
Thanks!
