Is there a reason my rhinoceros crash when I run the Psychometric Chart? (file with a very simple process)
Ilona
Ilona
Hi Ilona,
As Chris pointed out in here, you seem to use an older Service Release of Rhino (1 to 4). Update it to at least Rhino 5 SR5. If you can not, download the Rhino 5 evaluation version. Also be sure to use the latest (0.9.0076) Grasshopper version.
Ilona,
Djordje said it all. Thank you, Djordje!
I am pretty sure that the issue should go away upon Rhino update as it did with my peers but, if not, please let me know.
-Chris
Thanks for your reply. I have Rhino 5 SR4 with GH 0.9.0076. I’ll try to update: )
Hi, this is happening to me even I’m having Rhino 6. Have you found a solution?
Hi,@muath Please check the Units setting. Make sure that Rhino uses Meter as the Units.
Hi @minggangyin It is in Meters, I discovered it only happens when “wind speed” is connected.
@muath indeed, that has been happening to me too
Hi -
I downloaded the Grasshopper file that is attached to the first post in this thread (from the old forum) and ran it here without crashing:
What are you doing differently?
-wim
