Rhino inside Revit Openstudio problem
Hello all, I tried to run a very basic comfort analysis but the command just stop and stays there forever.
I copied the log and a screenshot.
Rhino inside Revit, everything latest version, I ran the Versioner just in case and restarted everything already. Any clue ?
Log:"2022-12-05 11:03:46 INFO: Started running CreateModelTransSchedules…
2022-12-05 11:03:46 INFO: Started running CreateModelOccSchedules…
2022-12-05 11:03:46 INFO: Started running CreateViewFactorModifiers…
2022-12-05 11:03:46 INFO: Started running CreateSkyDome…
2022-12-05 11:03:46 INFO: Started running SetModifiersFromConstructions…
2022-12-05 11:03:46 INFO: Started running CreateWea…
2022-12-05 11:03:47 INFO: Started running DynamicConstructionOutputs…
2022-12-05 11:03:47 INFO: …finished running CreateSkyDome in 0:00:00
2022-12-05 11:03:47 INFO: Started running CreateSimPar…
2022-12-05 11:03:47 INFO: …finished running CreateWea in 0:00:00
2022-12-05 11:03:47 INFO: Started running CreateResultInfo…
2022-12-05 11:03:47 INFO: Started running CreateDirectSky…
2022-12-05 11:03:47 INFO: …finished running CreateResultInfo in 0:00:00
2022-12-05 11:03:48 INFO: Started running CreateTotalSky…
2022-12-05 11:03:48 INFO: …finished running CreateSimPar in 0:00:00
2022-12-05 11:03:48 INFO: Started running GenerateSunpath…
2022-12-05 11:03:48 INFO: gendaymtx: reading weather tape ‘sky.wea’
2022-12-05 11:03:48 INFO: gendaymtx: location ‘Charlottesville-Albemarle AP’
2022-12-05 11:03:48 INFO: gendaymtx: (lat,long)=(38.1,78.5) degrees north, west
2022-12-05 11:03:48 INFO: gendaymtx: outputting suns to file
2022-12-05 11:03:48 INFO: gendaymtx: done.
2022-12-05 11:03:48 INFO: …finished running GenerateSunpath in 0:00:00
2022-12-05 11:03:48 INFO: Started running CopyResultInfo…
2022-12-05 11:03:48 INFO: copying input path…
2022-12-05 11:03:48 INFO: …finished running CopyResultInfo in 0:00:00
2022-12-05 11:03:48 INFO: Started running ParseSunUpHours…
2022-12-05 11:03:48 INFO: [{“path”: “sky.mtx”, “full_path”: “C:\Users\tlagarde\AppData\Local\Temp\b9a11292-6963-40d6-b91f-1431f819c2a6\tmpmjcav85j\sky.mtx”}]
2022-12-05 11:03:48 INFO: …finished running CreateDirectSky in 0:00:01
2022-12-05 11:03:49 INFO: [{“path”: “sky.mtx”, “full_path”: “C:\Users\tlagarde\AppData\Local\Temp\b9a11292-6963-40d6-b91f-1431f819c2a6\tmp4fgkl4br\sky.mtx”}]
2022-12-05 11:03:49 INFO: …finished running CreateTotalSky in 0:00:01
2022-12-05 11:03:49 INFO: …finished running ParseSunUpHours in 0:00:00
2022-12-05 11:03:49 INFO: …finished running CreateModelTransSchedules in 0:00:03
2022-12-05 11:03:49 INFO: …finished running CreateModelOccSchedules in 0:00:03
2022-12-05 11:03:50 INFO: …finished running DynamicConstructionOutputs in 0:00:03
2022-12-05 11:03:51 INFO: Started running RunEnergySimulation…
2022-12-05 11:03:53 INFO: …finished running SetModifiersFromConstructions in 0:00:06
2022-12-05 11:03:53 INFO: Started running CreateRadFolder…
2022-12-05 11:03:53 INFO: …finished running CreateViewFactorModifiers in 0:00:07
2022-12-05 11:03:57 INFO: C:\Users\tlagarde\AppData\Local\Temp\b9a11292-6963-40d6-b91f-1431f819c2a6\tmpj5r_rbh5c:\users\tlagarde\ladybug_tools\python\lib\site-packages\honeybee_radiance_folder\folder.py:632: UserWarning: TestRoom sensor grid has no view matrix receiver. It will not be included in three or five phase studies.
2022-12-05 11:03:57 INFO: ‘included in three or five phase studies.’ % grid[‘name’]
2022-12-05 11:03:57 INFO: …finished running CreateRadFolder in 0:00:04
2022-12-05 11:03:58 INFO: Started running CopyGridInfo…
2022-12-05 11:03:58 INFO: copying input path…
2022-12-05 11:03:58 INFO: …finished running CopyGridInfo in 0:00:00
2022-12-05 11:03:58 INFO: Started running SplitGridFolder…
2022-12-05 11:03:58 INFO: Started running CreateShadeTransOctrees…
2022-12-05 11:03:58 INFO: Started running CreateDynamicOctrees…
2022-12-05 11:03:58 INFO: Started running CreateOctree…
2022-12-05 11:03:58 INFO: Distributed 1 sensors among 1 grids with 1 sensors each.
2022-12-05 11:03:58 INFO: …finished running SplitGridFolder in 0:00:00
2022-12-05 11:03:58 INFO: Started running CreateOctreeWithSuns…
2022-12-05 11:03:59 INFO: …finished running CreateShadeTransOctrees in 0:00:00
2022-12-05 11:03:59 INFO: Started running CopyRedistInfo…
2022-12-05 11:03:59 INFO: copying input path…
2022-12-05 11:03:59 INFO: …finished running CopyRedistInfo in 0:00:00
2022-12-05 11:03:59 INFO: …finished running CreateDynamicOctrees in 0:00:00
2022-12-05 11:04:00 INFO: …finished running CreateOctree in 0:00:01
2022-12-05 11:04:00 INFO: …finished running CreateOctreeWithSuns in 0:00:01
2022-12-05 11:04:00 INFO: Started running GetEnclosureInfo…
2022-12-05 11:04:00 INFO: Started running ComputeSphericalViewFactors…
2022-12-05 11:04:01 INFO: Started running MirrorTheGrid…
2022-12-05 11:04:01 INFO: [
2022-12-05 11:04:01 INFO: “.\result.pts”,
2022-12-05 11:04:01 INFO: “.\result_ref.pts”
2022-12-05 11:04:01 INFO: ]
2022-12-05 11:04:01 INFO: …finished running ComputeSphericalViewFactors in 0:00:00
2022-12-05 11:04:01 INFO: …finished running MirrorTheGrid in 0:00:00
2022-12-05 11:04:01 INFO: C:\Users\tlagarde\AppData\Local\Temp\b9a11292-6963-40d6-b91f-1431f819c2a6\tmpft5pqdrg>C:
2022-12-05 11:04:01 INFO: C:\Users\tlagarde\AppData\Local\Temp\b9a11292-6963-40d6-b91f-1431f819c2a6\tmpft5pqdrg>“C:\openstudio-3.5.0\bin\openstudio.exe” -I “C:\Users\tlagarde\ladybug_tools\resources\measures\honeybee_openstudio_gem\lib” run -m -w “C:\Users\tlagarde\AppData\Local\Temp\b9a11292-6963-40d6-b91f-1431f819c2a6\tmpft5pqdrg\output\workflow.osw”
2022-12-05 11:04:01 INFO: Started running GroundReflectedSky…
2022-12-05 11:04:02 INFO: Started running DirectSun…
2022-12-05 11:04:02 INFO: Started running DirectSky…
2022-12-05 11:04:02 INFO: Started running TotalSky…
2022-12-05 11:04:03 INFO: …finished running DirectSun in 0:00:00
2022-12-05 11:04:03 INFO: [OpenStudio.Measure] <0> OSRunner is deprecated, use OpenStudio::Measure::OSRunner instead.
2022-12-05 11:04:03 INFO: [openstudio.EpwFile] <0> Successive data points (2000-Jan-31 to 1998-Feb-01, ending on line 753) are greater than 1 day apart in EPW file ‘C:/Users/tlagarde/AppData/Local/Temp/b9a11292-6963-40d6-b91f-1431f819c2a6/tmpft5pqdrg/weather.epw’. Data will be treated as typical (TMY)
2022-12-05 11:04:03 INFO: …finished running GroundReflectedSky in 0:00:01
2022-12-05 11:04:03 INFO: …finished running DirectSky in 0:00:01
2022-12-05 11:04:03 INFO: …finished running TotalSky in 0:00:01
2022-12-05 11:04:03 INFO: Started running OutputMatrixMath…
2022-12-05 11:04:04 INFO: …finished running GetEnclosureInfo in 0:00:03
2022-12-05 11:04:04 INFO: …finished running OutputMatrixMath in 0:00:00
2022-12-05 11:04:04 INFO: [OpenStudio.Measure] <0> OSArgumentMap is deprecated, use OpenStudio::Measure::OSArgumentMap instead.
2022-12-05 11:04:05 INFO: [OpenStudio.Measure] <0> OSArgumentMap is deprecated, use OpenStudio::Measure::OSArgumentMap instead.
And now a new bug but this time I got the log out, it’s probably a file path problem
Rhino inside Revit problem HB.txt (133.9 KB)
Probably solved by executing with administrator privileges this file set_python_path in C:\Users\NAME\ladybug_tools
I was using it but on a work computer locked by IT.
