Room Energy Metering
Hi Everyone.
I have a full residential building. Each room is separated from the main building. I need to meter the energy use of each room. Every unit has its own HVAC systems, lighting Etc.
Is there any easy way to measure the energy consumption per apartment? Something like IES Metering.
Thanks you,
Enrique
Yes, just make sure you are assigning the correct type of HVAC system using the HVAC components.
As long as the system is actually designed to supply each room separately (eg. a PTAC system), the results that you get out of the HB Read Room Energy Result component will be for each room.
