Hi @chris,
It seems the rel_humidity output of the RoomComfortResult component should be a “Relative Humidity (%)” type rather than “Fraction (%)” in order to be used without error as input of the LB PMV Comfort component.
Kind regards,
Romain
Hi @chris,
Thank you for catching this and reporting it, @Romain .
I just pushed a fix into the code base and you should be able to get it on your end with the “LB Versioner” component in an hour or two:
