I’m new to Grasshopper and hope to get some advice.
How to rotate an array at the same angle from different points? For instance, I have four rows and three columns of rectangles. I have specified each rotational point (1, 2, 3, and 4) as the center of rotation for each row. However, the array only rotates at one point (in this case point 1) but not at the designated center of rotation (points 1, 2, 3, and 4) when using the Rotate 3D component. How to rotate at the designated points? Your suggestions and input are very much appreciated. Thank you.
