Hello guys
I am trying to compute End Use Intensity (EUI) using Honeybee. I modeled my building using dragonfly “DF room 2D”.
I made a number slider for different building orientations to check the change of EUI with respect to building rotation. I used “Colibri TT Toolbox” to record inputs and outputs.
The problem is that the results are constant when using the component “HB Rotate”, while they are changing when using the built-in component of grasshopper “Rotate”.
It takes a short time when to simulate using “HB Rotate” as an input, and it takes a long time for the single run when using the built-in component “Rotate”.
Please I need a help to get the right results with the shortest time.
You could try using a value list instead of a Number Slider as your Colibri input to check if you still get the same results.
It would be easier if you could provide us with the gh file to test it.
thank you very much @Adarsh
it worked fine
But it takes a lot of time to recalculate the EUI for every rotation (about 6 minutes). Don’t you have a technique to speed up this process? I need thousands of iterations for different input variables.
