is there anyway to introduce this as a HBZone and run a daylight simulation on a non planar curvey facade surface in the image seen below?
Image below
Image below
You can use surface-by-surface modeling method for daylight:
http://hydrashare.github.io/hydra/viewer?owner=mostaphaRoudsari&fork=hydra_1&id=Surface_by_surface_geometry_preparation_for_daylight_simulation_I
and
http://hydrashare.github.io/hydra/viewer?owner=mostaphaRoudsari&fork=hydra_1&id=Surface_by_surface_geometry_preparation_for_daylight_simulation_II
Thanks MingboPeng,
Is it possible to also introduce HBGlazing to these non planar openings seen in the image above?
