Run Honeybee in an actual ArchiCAD model
Hello!
I have an architectural model I built in archicad, this model has a parametric facade. On this model I would like to run tests with Honeybee to test its light transmission, but all the tutorials I have found on the subject are working with models built in Grasshopper. Could someone please help me with the easiest way to run tests?
I have already successfully imported my model into Rhino. I am mostly stuck in the definition of the rooms.
Thanks in advance for your help!
Best wishes,
Árpád
