Hey everyone!
I’ve been trying to run the slab preprocessor on Honeybee but it doesn’t seem to work.
I used the IDF editor to create some Detailed Ground Heat Transfer objects which were then added to my HB model through the “add_str_” input of the ModelToOSM component. However, I figure EP is not calling the slab preprocessor, since the results are identical to when no additional string is input. Does anyone know if it’s actually possible to call this feature in Honeybee?
Here is the additional string input to the simulation component:
!-Generator IDFEditor 1.51
!-Option SortedOrder
!-NOTE: All comments with '!-' are ignored by the IDFEditor and are generated automatically.
!- Use '!' comments if they need to be retained when using the IDFEditor.
!- =========== ALL OBJECTS IN CLASS: GROUNDHEATTRANSFER:CONTROL ===========
GroundHeatTransfer:Control,
Control1, !- Name
No, !- Run Basement Preprocessor
Yes; !- Run Slab Preprocessor
!- =========== ALL OBJECTS IN CLASS: GROUNDHEATTRANSFER:SLAB:MATERIALS ===========
GroundHeatTransfer:Slab:Materials,
2, !- NMAT: Number of materials
0.2, !- ALBEDO: Surface Albedo: No Snow
0.4, !- ALBEDO: Surface Albedo: Snow
0.95, !- EPSLW: Surface Emissivity: No Snow
0.95, !- EPSLW: Surface Emissivity: Snow
75, !- Z0: Surface Roughness: No Snow {cm}
5, !- Z0: Surface Roughness: Snow {cm}
6, !- HIN: Indoor HConv: Downward Flow {W/m2-K}
9; !- HIN: Indoor HConv: Upward {W/m2-K}
!- =========== ALL OBJECTS IN CLASS: GROUNDHEATTRANSFER:SLAB:MATLPROPS ===========
GroundHeatTransfer:Slab:MatlProps,
2300, !- RHO: Slab Material density {kg/m3}
1200, !- RHO: Soil Density {kg/m3}
650, !- CP: Slab CP {J/kg-K}
1200, !- CP: Soil CP {J/kg-K}
0.9, !- TCON: Slab k {W/m-K}
1; !- TCON: Soil k {W/m-K}
!- =========== ALL OBJECTS IN CLASS: GROUNDHEATTRANSFER:SLAB:BOUNDCONDS ===========
GroundHeatTransfer:Slab:BoundConds,
FALSE, !- EVTR: Is surface evapotranspiration modeled
FALSE, !- FIXBC: is the lower boundary at a fixed temperature
, !- TDEEPin {C}
FALSE; !- USRHflag: Is the ground surface h specified by the user?
!- =========== ALL OBJECTS IN CLASS: GROUNDHEATTRANSFER:SLAB:BLDGPROPS ===========
GroundHeatTransfer:Slab:BldgProps,
10, !- IYRS: Number of years to iterate
0, !- Shape: Slab shape
4, !- HBLDG: Building height {m}
27.9, !- TIN1: January Indoor Average Temperature Setpoint {C}
28.03, !- TIN2: February Indoor Average Temperature Setpoint {C}
28.57, !- TIN3: March Indoor Average Temperature Setpoint {C}
27.64, !- TIN4: April Indoor Average Temperature Setpoint {C}
27.88, !- TIN5: May Indoor Average Temperature Setpoint {C}
27.62, !- TIN6: June Indoor Average Temperature Setpoint {C}
27.4, !- TIN7: July Indoor Average Temperature Setpoint {C}
28.15, !- TIN8: August Indoor Average Temperature Setpoint {C}
28.9, !- TIN9: September Indoor Average Temperature Setpoint {C}
28.59, !- TIN10: October Indoor Average Temperature Setpoint {C}
28.14, !- TIN11: November Indoor Average Temperature Setpoint {C}
27.86, !- TIN12: December Indoor Average Temperature Setpoint {C}
0, !- TINAmp: Daily Indoor sine wave variation amplitude {deltaC}
0.1; !- ConvTol: Convergence Tolerance
!- =========== ALL OBJECTS IN CLASS: GROUNDHEATTRANSFER:SLAB:INSULATION ===========
GroundHeatTransfer:Slab:Insulation,
0, !- RINS: R value of under slab insulation {m2-K/W}
0, !- DINS: Width of strip of under slab insulation {m}
0, !- RVINS: R value of vertical insulation {m2-K/W}
0, !- ZVINS: Depth of vertical insulation {m}
0; !- IVINS: Flag: Is there vertical insulation
!- =========== ALL OBJECTS IN CLASS: GROUNDHEATTRANSFER:SLAB:EQUIVALENTSLAB ===========
GroundHeatTransfer:Slab:EquivalentSlab,
1.62, !- APRatio: The area to perimeter ratio for this slab {m}
0.1, !- SLABDEPTH: Thickness of slab on grade {m}
15, !- CLEARANCE: Distance from edge of slab to domain edge {m}
15; !- ZCLEARANCE: Distance from bottom of slab to domain bottom {m}
