hi,
i download a openstudioexample.gh and find that the export to openstudio component(version0.0.55) function well but when i drag my export to openstudio conponent(version 0.0.57) it has a runtime error. i test the version 0.0.57 in some other files it also has the runtime error.
could anyone help me to solve the problem?
Hi Chao, Can you tell us what is the error? Did you check the outputs of ReadMe?
attached pic shows the readme panel
Did you try copying in the new libraries the ReadMe suggests? I can’t read the text in the image, but if it’s the same issue I’ve had previously (at Mostapha’s suggestion) I copied the new “CSharp” DLL’s over into my Ladybug directory structure, and the OS generator started working (again).
I second Nick’s comment and also suggest you to share your file if the problem persists.
