I have syncronize my grasshopper workflow with LB Sync Grasshopper File and the Run URBANopt project doesn’t work. I’m not sure if is related with some measure (tbd and set_ground_temperatures_monthly) or with some gem dependencies.
I have this error in one in.osw file:
E, [2023-09-27T11:16:56.159105 #16116] ERROR -- : Error activating gem :/ruby/2.7.0/specifications/public_suffix-5.0.1.gemspec
E, [2023-09-27T11:16:56.159612 #16116] ERROR -- : Error activating gem :/ruby/2.7.0/specifications/oslg-0.2.6.gemspec
E, [2023-09-27T11:16:56.159728 #16116] ERROR -- : Error activating gem :/ruby/2.7.0/specifications/osut-0.2.8.gemspec
E, [2023-09-27T11:16:56.159955 #16116] ERROR -- : Error activating gem :/ruby/2.7.0/bundler/specifications/tbd-3.2.2.gemspec
E, [2023-09-27T11:16:56.160903 #16116] ERROR -- : Error activating gem :/ruby/2.7.0/specifications/parser-3.2.2.1.gemspec
E, [2023-09-27T11:16:56.161063 #16116] ERROR -- : Error activating gem :/ruby/2.7.0/specifications/rubocop-ast-1.28.0.gemspec
E, [2023-09-27T11:16:56.161161 #16116] ERROR -- : Error activating gem :/ruby/2.7.0/specifications/regexp_parser-2.8.0.gemspec
E, [2023-09-27T11:16:56.161321 #16116] ERROR -- : Error activating gem :/ruby/2.7.0/specifications/parallel-1.19.1.gemspec
E, [2023-09-27T11:16:56.168423 #16116] ERROR -- : Error activating gem :/ruby/2.7.0/specifications/openstudio-extension-0.6.0.gemspec
[openstudio.XMLValidator] <1> xsdValidate.parseFileError: XML error 17.1871: Element 'descrption': This element is not expected. Expected is one of ( short_name, description, type ).
at C:/Users/Batiste/simulation_SII/27_09_Celra/D/.bundle/install/ruby/2.7.0/gems/urbanopt-reporting-0.8.0/lib/measures/default_feature_reports/measure.xml:42
[11:16:58.353605 ERROR] Found error in state 'initialization' with message ["OpenStudio measure C:/Users/Batiste/SUNO_lib/OutputData/measures/tbd called after after Energyplus simulation.:C:/Users/Batiste/simulation_SII/27_09_Celra/D/.bundle/install/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:168:in `block in validate_measures'\nC:/Users/Batiste/simulation_SII/27_09_Celra/D/.bundle/install/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:141:in `each'\nC:/Users/Batiste/simulation_SII/27_09_Celra/D/.bundle/install/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:141:in `each_with_index'\nC:/Users/Batiste/simulation_SII/27_09_Celra/D/.bundle/install/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:141:in `validate_measures'\nC:/Users/Batiste/simulation_SII/27_09_Celra/D/.bundle/install/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/jobs/run_initialization.rb:122:in `perform'\nC:/Users/Batiste/simulation_SII/27_09_Celra/D/.bundle/install/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:291:in `step'\nC:/Users/Batiste/simulation_SII/27_09_Celra/D/.bundle/install/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:233:in `run'\n:/openstudio_cli.rb:1187:in `execute'\n:/openstudio_cli.rb:817:in `execute'\n:/openstudio_cli.rb:1984:in `<main>'\neval:188:in `eval'\neval:188:in `require_embedded_absolute'\neval:173:in `block in require_embedded'\neval:167:in `each'\neval:167:in `require_embedded'\neval:126:in `require'\neval:3:in `<main>'"]}
