After failed installing OpenFOAM for Windows, we would like to try running Butterfly with other OpenFOAM platform. We managed to have a OpenFOAM running in Docker, however, Butterfly cannot connect to it. The issue seems related to some initial setup, shown as below.
I also attached a image that showing OpenFOAM is running and we can navigate to the case folder and run blockMesh manually. So it will be great if we can change some setting in Butterfly to allow it sending commands.
Anyone have some experience on running Butterfly with other OpenFOAM platform? Thanks.
Best
Bing
