I am trying to create a script that can do quick solar radiation analysis on multiple design options at the same time. I was wondering if Ladybug is able to handle these geometries as a data tree input. For instance, if I have 3 design options, I have 3 different buildings. Is it possible to run analysis on all 3 at the same time or would I have to use a loop to send the geometries one by one?
Any help is appreciated, thank you!
It seems a hard target.
Maybe the gate grasshopper component can help to save time of selecting geometries.
Simply you can just select all your buildings and all context geometry for shelter of all your 3 design(put them into 1 .3dm file), sharing 1 sun when running.
Besides,you can bake the result meshes into rhino for records and comparation.
Wish the ideas can help you.
This is the way to go. Search in the forum on how separate the results afterwards.
