I saw that Therm is bottom of the list because its windows-only, closed source and won’t work its way into Pollination. In the meantime though, I’d like some advice on getting Therm running while I have 1.2.x installed.
I’d like to install as few legacy tools as possible, what are your recommendations?
Hello @rdelgado,
If you install Ladybug 0.0.69 and Honeybee 0.0.66 [Legacy Plugins], THERM 7.6 and run it with Rhino 6, it’ll work with THERM.
It’s probably more than you wanna install, but it’s not a bad idea to have legacy plugins since the LBT 1.2 still doesn’t have all the components transferred.
Cheers
