upon installing the LBT 1.3.0 on a network VDI, I receive the following fatal error when running thermal analysis.
Openstudio 3.2 and EnergyPlus 9.5 are correctly installed, as per the compatibility matrix.
Runtime error (TypeErrorException): expected string, got NoneType
Traceback:
line 37, in isfile, “C:\Program Files\Rhino 6\Plug-ins\IronPython\Lib\genericpath.py”
line 318, in prepare_idf_for_simulation, “C:\Users\a.botti\ladybug_tools\python\Lib\site-packages\honeybee_energy\run.py”
line 624, in _run_idf_windows, “C:\Users\a.botti\ladybug_tools\python\Lib\site-packages\honeybee_energy\run.py”
line 376, in run_idf, “C:\Users\a.botti\ladybug_tools\python\Lib\site-packages\honeybee_energy\run.py”
line 237, in script
There is pretty clearly something wrong with the IronPython plugin for your Rhino installation and your problem doesn’t have anything to do with EnergyPlus or OpenStudio. What version of Rhino are you using (including the service release number)?
Maybe someone from the McNeel team might have an idea for what’s going on.
FYI, this is the line that is failing:
For some reason, we can’t check whether a file exists using the os module of your IronPython.
I took a closer look at your error message and realized that it’s not an issue with your Rhino IronPython and this is just a poor error message on my part. For some reason, your Honeybee model isn’t being translated into a valid OSM/IDF. Can you upload a minimal sample file that is needed to recreate the issue?
