Anyone know what this error means or know of any fix for this?
Hi @jtaniguchi You are using the old workflow for butterfly. I suggest you try to use BlueCore-CFD 2017.1 as the engine of butterfly.
Thanks @minggangyin for pointing that out! Can you also point me to a more current butterfly workflow?
Hi @jtaniguchi After installed BlueCore-CFD 2017.1, you can user Butterfly more fluent. You can create new issue and post some detailed question for next discussion.
