I have an error with the adaptative comfort map recipe:
Runtime error (PythonException): The recipe failed to run with the following summary:
Scheduled 36 tasks of which:
- 10 ran successfully:
- 1 CopyResultInfo(…)
- 1 CreateDirectSky(…)
- 1 CreateResultInfo(…)
- 1 CreateSimPar(…)
- 1 CreateSkyDome(…)
- 5 failed:
- 1 CreateModelOccSchedules(…)
- 1 CreateModelTransSchedules(…)
- 1 CreateViewFactorModifiers(…)
- 1 DynamicConstructionOutputs(…)
- 1 SetModifiersFromConstructions(…)
- 21 were left pending, among these:
- 21 had failed dependencies:
- 1 CopyGridInfo(…)
- 1 CopyRedistInfo(…)
- 1 CreateDynamicOctrees(…)
- 1 CreateOctree(…)
- 1 CreateOctreeWithSuns(…)
This progress looks
because there were failed tasks
Use the report_out attribute of recipe settings to see a full report.
Traceback:
Any thougths/ideas ?
Hi @Theophile - it is unlikely that anyone can help you with this issue with the information that you have provided here. See Ladybug Tools Forum Guidelines - faq - Ladybug Tools | Forum about the best practices for creating a question on the forum.
Hi @mostapha, sry about that, here’s a snapshot of the issue :
The issue seems to be coming from the room I created, because when i use the “HB Room From Solid” instead of the “HB Room” the recipe runs properly. But i have no warnings when i create the model.
Note that in both case the “simulated Box” is exactly the same size
I checked for my model’s unit but i’m in meters already. I also tried to run it without the antivirus (as some have said it could be the issue) but no noticed no changes.
I cannot share the GH file for now (as i’m a new user) but would be happy to send other screenshots of the file if necessary.
