Runtime Error with Interior Modifier and Construction in HB Solve Adjacency
Hi @Justin_Shultz ,
The second issue is a bug that has already been fixed in the latest development version of the plugin:
The first issue is a new bug. Thanks for finding and reporting it! I just pushed a fix:
You can get the new fix by running the LB Versioner in an hour or so and here is your updated file:
20220902_ParametricShapeEnergyDaylight_forLadybugDiscourse_CWM.gh (180.5 KB)
FYI, if you are hoping to model those interior Faces as 100% transparent, I would recommend using the air_boundary modifier that comes with honeybee since Radiance Glass modifiers can never be 100% invisible but the native honeybee air_boundary modifier is a Trans modifier that is truly invisible:
