Schedules <1 hour timestep - connecting IDF-files to simulation?
I am trying to make a three-season natural ventilation strategy for window operation.
The window operation should be able to follow a certain pattern of intervals and opening percentages e.g. two to three 20% openings with a duration of 5 minutes hourly.
From reading the post Forced natural ventilation - schedule shorter timestep, I found out that CSV scheduling does not allow for timestep <1 hour (8760 yearly), but instead that I could use IDF schedule, given that I edit the text manually, as seen below.
As a test, I am trying to get this to work with a 30-minute timestep, which is causing issues with my schedule not being recognized by the “HoneyBee_Set EP Air Flow”-component.
Have anyone had the same issue or know how to connect schedIDFText-files to a simulation?
My progress so far can be seen in the screenshot below:
Thank you all for the great community
Best regards
Oscar M
There are 2 different names:
template_PULSE for the definition of the schedule.
PULSE for the name in the input.
Decide the name you want and use it for both cases.
Thank you for the fast answer!
It seems that using the same name (PULSE) for both cases, simply uses the hourly timestep schedule and not the half-hourly timestep, that i made by editing the first schedIDFText-file. I have tried to illustrate this in the inserted 3D chart visualization.
Could the issue be related to the actual format of the panel after editing?
Or a wrong connection into the simulation/HBZones?
I attached my .gh-file, as an extra example:
half_hourly_timesteps_issue.gh (804.6 KB)
Best regards
Oscar M
For people having issues creating a sub-hourly schedule, @AbrahamYezioro’s posts on the linked topic helped creating sub-schedules!
Thank you once again, @AbrahamYezioro!
