Scritping in R8, ironpython2 and python 3?
Hi @LittleBuddha ,
Yes the new Rhino python landscape is confusing (IMO). The short version is: you should continue to use the older GhPython components whenever you want to work with the LBT SDK or LBT objects in your Rhino/Grasshopper files.
The slightly longer version is:
Rhino & Grasshopper have 3 distinct python interpreters now; a 3.x one, an IronPython one, and the older GhPython one. These three interpreters are fully separate from one another, and while it is technically possible to pass some very simple objects between interpreters, it is not recommended, and certainly complex objects like LBT rooms, models, etc cannot be easily moved between them.
The three interpreters do not share system path or dependency environments, and so installing the LBT libraries on the GhPython one will not make them available on the IronPython or v3 ones.
Unless / until the LBT components themselves are updated to work in the ‘new’ interpreters, we will just need to stick with the ‘old’ one.
hope that helps!
best,
@edpmay
