Hello all,
I’m using the honeybee+ tools to run sDA and ASE values. From what I read, only the DC and 5-phase recipes have direct sun contribution and therefore can be used for the ASE calculation. However i’m running into some problems where my run_radiance is failing. It says that it fails to load results.
Any help would be greatly appreciated! Thanks!sdaase.gh (596.4 KB)
Is there a particular reason you’re using Honeybee+ for ASE? This ecipe from @chris is also does the same thing.
Oh Thanks! I didn’t see this before.
I tried running this with my EPW, but there is no value direct normal illuminance… is this normal? I have direct normal radiation, but for illuminance values they are all zeros…
I am not sure why that is the case. Which weather station are you using?
