Hi
Is there a way by which I can get the sDA and ASE results for each space(analysis plane) in a floorplate? Currently, I’m getting the results for the entire area considered and not for each surface/space as selected to generate the gridpoints.
DAYLIGHT sDA & ASE - SCRIPT lbt 1.8.gh (678.8 KB)
it’s because you did flatten all of your grid points and joined your
mesh in one grid. If you want to have them per analysis plane you shouldn’t flatten them…
is this answering your question?
DAYLIGHT sDA & ASE - SCRIPT lbt 1.8 (1).gh (685.9 KB)
Yes it is. But that does create an error in the LB spatial heat map component. Is there a way to make both these components work properly?
try to keep the same structure of input results DA/mesh size… it works on my end ![]()
DAYLIGHT sDA & ASE - SCRIPT lbt 1.8 (1).gh (682.8 KB)
