hello when I try to plot I am getting this error.
and can anyone help with the ASE calculation please
@Teja5zz This issue is something about the result visualization.not about sDA calculation. It remind you that the result is not suitable for the mesh. Please upload your file for further discussion.
here I’m attaching the files
https://drive.google.com/drive/folders/1Sv7b8xH-tu4AaOCwT5AfMJcbM3rTH2bd?usp=sharing
thank you very much , I’ll run the simulations again.
I am getting the result for UDI,DA,CDA except sDA. I’m getting the same error
ERROR
- length of the results [=1] is not equal to the number of mesh faces [=140] or mesh vertices[=165].
@Teja5zz sDA is different from other aforementioned indices such as UDI, DA, CDA. it is just a number not a list of numbers, so you can not expect visual output for it.
Hello, I have a problem similar to this and I was wondering if I could get some feedback!
https://discourse.ladybug.tools/t/sda-and-ase-calculation/9318/8
