Hi @chris,
I’ve been playing around with the SDK and came across this error - have you got any idea what’s going wrong here?
I can work around it as calling the method this way works fine, but would be good to understand what’s going on.
Charlie
Hi @charlie.brooker,
This is how I would do it.
from ladybug_comfort import adaptive
help(adaptive)
ladybug_comfort is the whole package. When you import it as a module it will reference to the __init__.py file in the package. And there is no adaptive module inside that file. Try this code.
import ladybug_comfort as lc
print(lc.__file__)
The reason that the first example works is that adaptive is a module inside ladybug_comfort and it is linked to ladybug_comfor/adaptive.py.
Python packaging is a bit strange!
