I am getting an error with the selectSkyMtx component when inputting large arrays of HOY inputs. See attached file.
The error says “1. Solution exception:unsupported operand type(s) for +: ‘str’ and ‘int’”.
It occurs on lines 42 and 141, where the HOY seems to be calculated and called. The error only appears when I have at least 1000 HOY inputs or so. The data seems to be good, but I can’t reasonably check every data set to be sure. I would feel more comfotable if I knew what was causing the error. I just can’t figure this one out.
My goal is to combine many hourly sky domes into a single cumulative dome that responds to complex occupancy schedules or heating/cooling schedules. The analysis period does not allow this level of refinement. Is there a better way to accomplish what I want using standard Ladybug components?
Thank you in advance for your help.
Ladybug test.gh (56.2 KB)
USA_MO_St.Louis-Lambert.Intl.AP.724340_TMY3.epw (1.57 MB)
