Is it possible to simulate a semi-transparent PV with Honeybee and Laydybug? If not, What software can be used to simulate it?
What metric are you looking to output?
Solar irradiance below the panel? If so, use Honeybee’s Radiance capabilities.
Hi Chris @chris,
can you tel the name of the component and how we can use it to calculate solar irradiance under the panels? thanks in advance!
If you are looking to run a simulation to give you hourly irradiance with the new LBT grasshopper plugin, you should use the HB Annual Irradiance recipe.
I didn’t understand how to make semi-transparent photovoltaic cells. Can someone guide me? Thank you.
