Hi everyone,
I have an issue creating sensor grids for annual irradiance. There are 50 rooms in the building, out of which I have extracted 5 rooms. Then it is input into the component HB sensor grid from rooms. But there is no grid output.
Hi everyone,
Hey @76animesh ,
You should use a _dist_floor_
that is greater than zero. Also, you should check to be sure that those rooms actually have floor geometries.
