Hello Community,
Im currently looking into the possibility of visualizing different spotlights being reflected fy mirrors. There are many objects inbetween so my objective is to figure out where the light can be directed to in terms of areas, faces and so on.
As far as i know the recipes to check where light can be is only direct not accounting for intentional reflective elements.
The Complexity is that the reflectors can be adjustet in angle to direct the light.
Currently im using a sensor point i direct the light to so possibly i can just distribute this point to different locations and run simulations after another to get an idea but i though of maybe there is a more elegant solution to visualize the different reflective angle possibilities and the possible spots the sunlight can be directed to.
Thanks!
