Is there any way I can filter the solar radiation values and face area based on certain building height. For instance, the height of the building is 100 ft, having 6 faces. I want to get two separated ‘total solar radiation’ values and area for individual surfaces, one is from bottom base to 25 ft and another is from 25 ft to 100 ft.
(Attached here, is an example file. As I am working with rhino.inside with Revit models, I don’t want to split the model by planes through grasshopper before solar radiation analysis. I am wondering if I can get the value after conducting the radiation analysis.)
Radiation analysis.gh (427.5 KB)
Thank you!
