Set and Render in Radiance the RGB-colours to the HB_Modifier
Hallo dear Ladybuggers
Is possible to add and assign a RGB color to a material and render it using Radiance and then visualize for example after a PITView simulation, via HDR? Or is only possible to set the light reflectance?
Thanks and best regards
Yes.
You can make colored RGB Radiance modifiers using any of the components that end in 3 under the HB-Radiance 1::Modifiers section.
If you use the HB Custom Sky component, you can also create colored skies as long as the ratio between direct and diffuse radiation falls within realistic ranges.
So yea, colors are fully supported.
