Some OS measures require the Ashrae climate zone to set some parameters internally (in my case it relates to the configuration of Radiant ceiling panels).
Is there a way in HB to set the Ashrae Climate Zone to an OpenStudio model?
I have tried to load the Set Climate Zone from Weather Data measure in HB, but for some reason it throws an error.
That “Set ASHRAE Climate Zone” measure is a good sample for testing. It seems the honeybee-energy core library had a bug related to measures that don’t have any input arguments. I just pushed a fix:
… and you’ll can see that you can now load and apply that measure to your model:
