I am able to set multiple hours to generate the sky files and produce the same number of HDR files as hours, but if I additionally try to plug in multiple months, it seems as if the result files don’t write properly. Is there a better way to run 3 months x 6 hours = 18 HDR / TIF files?
Slider + FLY component will do that for you.
The FLY component wasn’t launching the study for some reason. I came up with this workaround, but I need to remember to turn off the timer after 3 iterations. Not my favorite.
Do you mind uploading a minimal file of what you are trying to do?
FLY should work fine or Colibri. The timer doesn’t look appropriate for me.
Since no geometry was defined in your file i didn"t check the full process.
I believe this should work.
Glare Troubleshooting FLY Component_AY.gh (64.4 KB)
