Set path for SQL file
Hi
I’ve setup an iterative simulation logic and would like to save the SQL file from every iteration.
Is it possible to set the file path for the SQL file from the ModelToOSM component?
Or maybe there’s a better way to achieve what i’m trying to do?
@MOSTI I believe (its been a little while), if each iteration has a different model name then you can accumulate the outputs of all iterations without them being overwritten.
Hopefully that helps
