Setting hourly air temperatures for the ladybug UTCI
For the below ladybug component, the air temp/relative humidity currently reads from the EPW file. Can we define custom hourly air temperatures/RH (8760 values) into this component?
Hey @AAdeeb
Yes, you should be able to do this using a data file or even a panel to import the custom 8760 values. You could do it similar to this;
