Hi @mostapha,
It’s been a while since I’ve been Ladybugging, good to be back
Anywho, I’m pretty sure I’ve tracked down a bug that I couldn’t find any precedence for on the board:
When running the radiationAnalysis component, any GHPython component (including ones in other Grasshopper definitions within the same Rhino session) that sets scriptcontext.doc to Rhino.RhinoDoc.ActiveDoc seems to break the Ladybug dataflow, resulting in this message from radiationAnalysis (i.e. selectedSkyMtx failed to collect data! Use selectSkyMtx component to generate the selectedSkyMtx):
I’ve reproduced this behaviour on a number or working definitions (i.e. open definition, run it to verify it’s working, paste in GHPython component setting scriptcontext.doc, recompute definition to verify breakage).
I’m running a bunch of stuff both upstream and downstream that interfaces with the Rhino document, so this is a bit of a spanner in the works. Perhaps you have an idea of what might be causing this, that I can solve as is (i.e. by messing with the LadyBug GHPython code)?
Cheers and best,
Anders
Edit: Also, is it better to report things like on the github repo?
