Setting Temperature Setpoints
Hi everybody;
Honeybee bring us some results about heating,cooling etc.I want to know,what is the comfort temperature in this simulation.how can define comfort temperature in this file?
and how can define a system for supporting heating and cooling that is needed?
my first project.gh (558 KB)
Look for “Honeybee_Set EnergyPlus Zone Thresholds” component. You can set heating and cooling setpoints and setbacks.
Hi Mostapha, does the set-point/set-back use indoor air dry-bulb temperature or operative temperature?
@Tiantian,
It uses the air temperature.
Hi Mostapha, I want to set heating setpoint for one of my zones (pool) to 27 degree c but I get error. I tested and see I can not set above 24 I will get this error:
  1. Solution exception: ** Fatal ** Program terminates due to above conditions.
    how can I solve it?
    can you please help me?
I sounds like you set your heating setpoint to be above the cooling setpoint, @hamed.sangin . Just make sure that you change both of them together so that the cooling setpoint is above the heating one and things should work.
