Hello, I have a question while doing research on buildings used for crop production.
Can I set the brightness of the light to be strong?
My crops usually require 8000-9000 Lux.
If sunlight is insufficient, artificial light must be supplemented. I wonder if it can be set to satisfy this.
HB Lighting has _watts_per_area, can I adjust it there? -
Can I adjust the distance of the lights?
If the lights are suspended from the ceiling, you won’t get 8000-9000 lux.
Even in real buildings, the lights are lowered so that the distance between the crop and the light is close.
So I wonder if this setting is possible in Honeybee.
Thank you for always.
