Hi guys. I tired to calibrate the weather file but after replace the temperature and convert the file in energyplus weather converter, the script with new epw file cannot run (I already added the ddy file) the warning and severe are shown below
Current document units is in Meters
Conversion to Meters will be applied = 1.000
Current working directory is set to: C:\honeybee\0913-fieldwork\OpenStudio
Model saved to: C:\honeybee\0913-fieldwork\OpenStudio\0913-fieldwork.osm
OSM > IDF: C:/honeybee/0913-fieldwork/OpenStudio/0913-fieldwork/ModelToIdf/in.idf
Program Version,EnergyPlus, Version 9.3.0-baff08990c, YMD=2020.09.16 13:13,
** Warning ** ManageSizing: For a zone sizing run, there must be at least 1 Sizing:Zone input object. SimulationControl Zone Sizing option ignored.
** Warning ** ManageSizing: For a plant sizing run, there must be at least 1 Sizing:Plant object input. SimulationControl Plant Sizing option ignored.
** Warning ** ProcessScheduleInput: Schedule:Constant=“ALWAYS ON DISCRETE”, Blank Schedule Type Limits Name input – will not be validated.
** Warning ** ProcessScheduleInput: Schedule:Constant=“ALWAYS OFF DISCRETE”, Blank Schedule Type Limits Name input – will not be validated.
** Warning ** ProcessScheduleInput: Schedule:Constant=“ALWAYS ON CONTINUOUS”, Blank Schedule Type Limits Name input – will not be validated.
** Warning ** GetHTSurfaceData: Surfaces with interface to Ground found but no “Ground Temperatures” were input.
** ~~~ ** Found first in surface=EAST_SRF_4
** ~~~ ** Defaults, constant throughout the year of (18.0) will be used.
** Severe ** For autosizing of ZoneHVAC:IdealLoadsAirSystem EAST IDEAL LOADS AIR SYSTEM, a zone sizing run must be done.
** ~~~ ** No “Sizing:Zone” objects were entered.
** Fatal ** Program terminates due to previously shown condition(s).
…Summary of Errors that led to program termination:
… Reference severe error count=1
… Last severe error=For autosizing of ZoneHVAC:IdealLoadsAirSystem EAST IDEAL LOADS AIR SYSTEM, a zone sizing run must be done.
************* Warning: Node connection errors not checked - most system input has not been read (see previous warning).
************* Fatal error – final processing. Program exited before simulations began. See previous error messages.
************* EnergyPlus Sizing Error Summary. During Sizing: 2 Warning; 0 Severe Errors.
************* EnergyPlus Terminated–Fatal Error Detected. 6 Warning; 1 Severe Errors; Elapsed Time=00hr 00min 0.30sec
Please help, thank you!
