I’m using type 1 of shading (shades), internal roller shade, with type 1 of solar control (OnIfHighSolarOnWindow). Would be great if I get a clarification on the points below.
would the solar radiation set-point override the default schedule? or is there a need to create an AlwaysOff schedule so that schedule does not interfere with the solar setpoint?
Temperatures and solar gains results did not seem to change when I change the solar radiation setpoint between different values, however, I changed to connect the shades through HBObjWShades rather than shading context and seems to give a change in results when varying between setpoints. Can someone please explain to me how would I iterate between having one regular overhang (which is picked up only if I connect the shades through context shading) and type 1 of shade roller (which is picked up only if I connect the shades through HBObjWShades)?
Cheers!
