I am trying to create a shading mask on surface for some bus stop shading devices and I have tried so much but I could not get any result. Every time I put the context into shading mask and shading mask II it will took a long time and grasshopper would crash and would error not responding. I don’t know why because I do not have a complicated model. It is just a simple bus stop. It is not like a error message that will be show on. Grasshopper will stop working and will be not responding. Does anybody have any idea what might be the problem? I attached my gh and my rhino file so you can better understand the problem.
Yes the problem is that I exported the model from SketchUp, I only introduced the roof surface to grasshopper but probably there are still so much details. Because I have 8 of these models exported from Sketch Up do you have any other suggestion beside creating the models? Because that would take so long. Is there a way in which I can make the model simpler itself?
Abraham is spot on. Your context geometry needed to be very simple. I have made a simple polysurface to use as a context in your file. Everything works with that polysurface. One more thing. As I was testing the polysurface, I noted that the Ladybug_Shading Mask_II was not outputting anything from maskedSkyDome. I went ahead and fixed that in the component, so for now, it will work fo you. I will also share the same issue with masters to fix this in a permanent manner.
