Hi everyone,
I wanted to try and test the shading mask components for some further analysis. Problem is, that when trying to drag the Shading Mask component, on an empty canvas, the whole Rhino crashes (even without any geometry in the model yet).
When using the Shading Mask II component, I get no results and I am left with this warning:
- Solution exception:‘NoneType’ object has no attribute ‘PointAtNormalizedLength’.
I tried connecting the context as a whole as well as individual faces with the same result. Tomorrow I will also try this on a desktop PC. I am running it on Rhino 7 together with the Ladybug Legacy 0.69.
Is there something I am doing wrong, or may the problem be somewhere in my installation?
Simple file is here: shading_mask_problem.gh (383.5 KB)
