I’m modelling a shadow mask for a proposed building.
The North- east and North -West facing windows have shading. I wanted to see if either vertical or horizontal shading would be fit for the windows. However I am not getting the correct result output from the shading mask.
The building was imported from sketchup and some parts were removed for the ease of usage. The window is like a double window where one on the bottom is openable whereas the upper part of the window is not and the vertical/ horizontal fins are placed at the upper level.
To show the generated shading, I have placed the points at the sill level 0.01 m above it of the bottom most window level.
The results:
Working_Shadow mask.gh (416.1 KB)
Isnt the result supposed to appear like the image below?
I have attached the grasshopper - ladybug file for reference. However I m not able to upload the geometry separately if required.
