after making shading
component show this error msg : 1. Solution exception:Local variable ‘schedCntrlType’ referenced before assignment.
even in example that i dl from hydra i got this problem!
Try to update the file components. If this doesn’t work upload your file.
Kindly setup a profile picture please
Hi Ali.
You can also use a newer version of E+ (9.0 and more than that), this might help and solve your problem.
